"Changes in models" 37-93 or 38-93
Hi all
Wasn't there a revision for Philco 37-93 or 38-93 published in Philco's "Changes in models" ? I thought there was and I can't find it. Icon_confused
Ed 8)
Chuck?
No Philco Production Changes In Models for the 37-93 or the 38-93 (leftover 37s in a new cabinet). From what I can tell there were very few made; no figures for the 1937 version, but only 5,300 of the 1938 versions were made.
Philco 91 Tuning Condenser
There are currently 6645 online users. [Complete List]
» 2 Member(s) | 6643 Guest(s)
