Capacitors in Philco model 60-121
Hello friends.
My name is Jose Antonio and i have some questions about some capacitors in a philco mdel 60-121.
First pardon for my english, is not good.
Well, i have a Philco model 60-121 and i am restoring now this radio.
I need to know the conections in the bakelite block condensers.
In this page i see the models 3615-AJ and the 8035-D:
http://www.philcorepairbench.com/bblokcap.htm
But i need to know how are the capacitors in the models 4989-Z, 8035-B and 3903-AP (The conections Icon_wink ).
Other question: Is correct the datas about the 3615-AJ in the page? I say this because the lugs used are 1, 3, 6 and 8 and the conds lugs are 1-3 and 1-6, the lug 8 is not conect.
Thanks for all.
Jose Antonio
Take a look at this page and see if it helps you:
http://philcoradio.com/tech/blocks.htm
Hello Ed.
Thanks for the information, it is perfect for me.
Bye and thanks.
Eico 232 VTVM Schematic
