philco schematic
are sam's schematics available on the web? - i am trying to locate a copy of a schematic for a small philco clock radio (model D-736). i believe it is sam's folder # 321.
thanks .. mike
Try Ernst's site:
Firelands Radios for 50s Philco service info.
http://www.firelandsradios.com/PhilcoService/index.htm
Hi Mike,
The Schematic Bank has a copy of the schematic in DJVU format:
http://techpreservation.dyndns.org/schem...6_106.djvu
Carl
Northern Panhandle, WV
I've found a lot of schematics at http://www.nostalgiaair.org in pdf
Ryan
There are currently 9362 online users. [Complete List]
» 3 Member(s) | 9359 Guest(s)
