Philco O8WATR
would anyone have any information on this receiver.I just picked it up from a yard sale.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
There should be model numbers somewhere, generally on the back.
but its labeled Philco-Ford, so I guess it is post 1966, when Ford rebranded Philco.
-Mars
Yes,I have the model number O8WATR.I just cant find any info
might be of some use:
http://www.worthpoint.com/worthopedia/vi...-130326186
-Mars
Thanks.I looked at that and it tells me a good bit but I wonder what year exactly it was in the 60s
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2608 online users. [Complete List]
» 1 Member(s) | 2607 Guest(s)
