Replacing rubber insulated wiring
Threads: 32
City: Nipomo
State, Province, Country: CA
Hi everyone, I'm new to this radio thing and admit that I have a tremendous amount to learn.
I have a couple of 42-PT94's that I'm going to try to re-cap and see where it goes from there. The wiring is rubber insulated and some of it looks pretty cruddy, some crumbling. What wire should I use to replace with? Stranded cloth insulated, 20 ga.? Solid vinyl insulated 22 ga.? Are colors just to visually be able to trace them, or is there a color code that I need to adhere to?
Thanks for your help now and for all that I'll need down the road.
Alan
Threads: 50
City: Apple Creek
State, Province, Country: Ohio
Hello Alan and welcome.
That old crumbling wiring is the pits to deal with. There are usually two roads people generally take when dealing with it. Unsolder one end of a wire and slide the same (or close) color heat shrink over the wire, and reconnect. The other road is more tedious and time consuming that would be removing the wires one at a time and replace with the same color wire. I use either strand or solid wire from the 18 - 22 gauge size.
My opinion is to use the same color or as close to the original as possible, as this will help if you run into a problem down the road and someone with the same radio tries to help out.
I get my wire from here. They have every color you would need.
http://www.wesbellwireandcable.com/UL101...20-10.html
Hi Alan, and welcome!
Keith has given you some good advice. I also resleeve the original wires with color-coded heat shrink tubing. A heat gun set on low, or an Aladdin lamp, will shrink the tubing for you.
A comment on what Keith said re: using the same colors as the original. I have run across Philcos of the same model number that do not use the same color rubber insulation. It appears that at times, they just used whatever they had on hand at the time rather than adhering to any sort of a standard. It looks like they only adhered to a standard on IF transformer leads, for the most part.
I've had enough of those nightmare sets cross my bench, so I'm pretty well versed on Philcos with rubber-covered wiring. And I still dislike working on them. But they usually do reward your efforts with very good performance, especially the larger multi-tube models.
Threads: 17
City: Yorkville IL
Hi Alan,
What Keith and Ron said +1  . My first radio was a 41-300, yes it is tedious but they do reward you with a nice sounding radio. Don't be afraid to ask anything these guys are the best. I would have given up if it wasn't for their sage advise and direction.
Glenn
Threads: 32
City: Nipomo
Thanks guys for such warm responses. I know that you'll keep me psyched to see this through.
Much, much appreciation,
Alan
Threads: 54
I like to use either 18 or 2O gauge solid wire if it's similar to what the set originally used, 22 gauge is a bit flimsy to work with. Vinyle insulated wire makes a decent substitute for the rubber stuff although it's hard to find colours that are an exact match.
Threads: 13
City: Montreal, Qc
Not talking about the gauge, but look at the lug strips used in the chassis, and if they used solid wires or stranded ones.
I mention this as, when I started to recap/rewire my 47-1230, I got stranded wires of appreciable size.
Appears the type of lug strip used in it works like a charm with solid wires, and is a bit more iffy (but still very doable) with stranded. They are sort of T-Shaped lugs, you simply twist the solid wire around, heat, put solder, and are done. Stranded don't hold that easy; so I would have been better to get solid ones while I was at it; and the price was about the same (maybe even cheaper if I recall)
But as long as your wire is big enough for the power passing trough it, you're all set. The rest is mainly cosmetics.
-Mars
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
There are currently 5092 online users. [Complete List] » 1 Member(s) | 5091 Guest(s)
