Schematic for Philco 42-PT94
Hi all,
Why is it that when I go to Rider's to find a schematic for the 42-PT94 I just find a page of notes and changes, not a schematic. Is the schematic the same as another model?
Alan
Alan,
The schematic is on page 14-114:
http://www.nostalgiaair.org/PagesByModel...014177.pdf
Carl
Northern Panhandle, WV
Thanks Carl,
I appreciate your response, I don't know why I wasn't able to come up with it. I did just find it also in a Beitman publication.
Thanks again, this phorum is so great!
Alan
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6378 online users. [Complete List]
» 1 Member(s) | 6377 Guest(s)
