Philco? Unknow
Hola, necesito conocer que modelo de Philco corresponde esta imagen.
Hello, I need know this model
[img][Image: http://img242.imageshack.us/img242/8159/...nowql8.jpg][/img]
Thanks you
Gracias anticipadas.
Hi,
That's not Philco radio. The dial looks like it could be a Silvertone model.
Nice looking radio.
thanks for the reply and the link, gracias por la respuesta y el enlace.
He visionado los modelos de silvertone y no en encontrado el modelo
I see the silvertone models and I have not find the model.
Tanks you
There are currently 8744 online users. [Complete List]
» 4 Member(s) | 8740 Guest(s)
AvatarAvatarAvatarAvatar
