Philco decal needed
Just finished one of my 16B's and need to buy the Philco decal as the cabinet was completely stripped when I bought it. Anyone know who sells the correct one for this cabinet?
[Image: http://i989.photobucket.com/albums/af14/...rchtop.jpg]
Click the thumbnail to view a larger photo. (edited by site admin)
What you want looks like this:
[Image: http://i326.photobucket.com/albums/k420/...36phil.jpg]
If you order the PH-HiFi decal set from Radio Daze, and use one of the decals with the words "HIGH FIDELITY" in small block letters underneath the PHILCO trademark, cut off the "HIGH FIDELITY" and you will have an authentic decal.
By the way, your 16B sure looks purty. Good job! Icon_thumbup
Thank you very much Ron. I would have never figured out which decal to use!
There are currently 10137 online users. [Complete List]
» 3 Member(s) | 10134 Guest(s)
