Antenna Transformer
Hello,
I'm looking for any information regarding the antenna transformer on a Philco 60. (32-1047) Looks as though I'm going to need to rewind this part so, any diagrams, pin-outs, windings etc would be appreciated.
Thanks much,
-Brett
There are several variants of the 60. Do not know if they all have the same ant xfrmr but you might research this. This site has a great site devoted to the different 60 models.
Playthings of the Past may have what you are looking for, Gary has MANY original parts there.
I'm pretty sure the Model 60's use the same antenna coil.
I was searching on "Antenna Transformer", but last night using "Antenna Coil", I found much more information:
http://photobucket.com/images/Philco%20a...odel%2060/
http://www.philcorepairbench.com/tips/svctip36.htm
Still looking for the wire gauge and the number of turns.
Thanks.
-Brett
Just found this link in the site.
http://www.philcoradio.com/phorum/showth...p?tid=1927
Very helpful and I think it answers my questions.
Regards,
-Brett
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3462 online users. [Complete List]
» 2 Member(s) | 3460 Guest(s)
