Lubricant for Variable Capacitor
Threads: 569
What is a good lubrication for the tuning cap?
Is there something I can use that's readily available, like petroleum jelly, or does Radio Shack sell something?
Or maybe, an auto parts store?
I'd prefer something that I put in and do not touch it ever again (I am sure the old lubrication was there since the inception - but I washed the cap in the dishwasher so it got stripped off)
Threads: 268
I use a bit of white grease myself, for better or worst.
Threads: 27
City: Rochester, NY
Sewing machine type oil. Careful not to over-do.
Threads: 55
City: Evanston, IL
I use Lubriplate - a white grease.
Chuck
Threads: 40
City: Lehighton
State, Province, Country: PA
TimC Wrote:Sewing machine type oil. Careful not to over-do. Same here.
Larry
Threads: 569
Than you all guys.
I take it, no one uses WD-40?
Actually, I found yesterday "WD-40 with white grease". What do you think?
Threads: 569
There is a can of "Crisco" in my fridge. Use it to season my cast iron skillets.
It's white.
I even came up with a commercial slogan for "Crisco" (hope they see it and pay me for it):
" Crisco! Another white grease!"
PS. Went to automotive store, bought "Liquid wrench" with While Lithium Grease in it.
Worked like a charm. All squeaks and groans are gone!
Than you guys!
Threads: 18
Agee with all for once. I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way. Of course I do this after blasting the old crud out of there with deoxit and letting it dry over night. Sewing machine or instrument oil probably just as good.
Threads: 569
codefox1 Wrote:I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way.
Actually, there is pre-mixed WD40+White Lithium Grease sold on the same shelf with regular WD40 and the "Liquid wrench" in most hardware / automotive stores.
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
