42-335T
The 42-335T I just got is not a AC-DC set ,it has a power transformer , I doubled check with the RIDERS ,incase the chassie had been changed ,and it has a power transformer ,In the Philco Radio Gallary it says it's works on AC or DC?
Correct, this 1942 model does have a power transformer, so it's AC only.
The Gallery page needs a correction.
Chuck
When errors are found in the Philcoradio.com website, I need to be contacted so that I can make necessary changes.
http://www.philcoradio.com/contact.htm
The error has been corrected.
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2353 online users. [Complete List]
» 1 Member(s) | 2352 Guest(s)
