PREDICTA...
After a few years and a few headaches, mine is finally restored. I have reason to think mine was used by either Holiday Inn or Howard Johnson's. I still need to play with 6DR7's, since the vertical isn't perfect, but it works.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Visit the world's worst TV restoration website.
http://evilfurnaceman.tripod.com
that's a nice set for sure!
-Mars
I confirmed slight leakage in the vertical output tube. Now, the linearity is as close as I can get it. Here's a better shot.
Nice looking set! Good job. I've got a Siesta that's on my todo list one of these years. I hear they are kind of a pain to work on.
http://www.flickr.com/photos/42774321@N0...otostream/
It should say I haven't had a chance to check it over...
Tnx for posting. It gives some of slow pokes some encouragement.
I just seen a predicta sell on ebay for $1800.00 wasnt the same model but close
Eico 232 VTVM Schematic
There are currently 6695 online users. [Complete List]
» 2 Member(s) | 6693 Guest(s)
