pilot lamp
What is the bulb for a 34-2039 philco part number? Thanks Doug
A #55.
From my Parts Values section of my site:
http://www.philcorepairbench.com/lamps.htm
Chuck
Ty TY Doug
Chuck, what color was the end of the 34-2210 painted? I have a good supply of the #47s but to be strictly accurate I intend to gently dip the tip in some good old fashioned Testor's model paint.
Here are some pics of the elusive 34-2210 dial bulb. They are a tung sol #44 bulb, frosted and with a black painted top.
Gene
Admin Note: The 4 images attached to this post no longer exist.
91H Code 126 Restore
