Philco 84 ("38-1139")
Philco 84 (the radio is a model 84)
O K chuck if you are there, you were correct, the osc coil is open several places. There is 15 turns on the cathode winding and only 5 were in one piece.
Did you ever rewind one of those coils?? The wire is very fine and it is cotton covered. Would I have to use cotton covered wire??? I have never rewound a coil with wire so fine. Where would I get the wire??? ETC
Any help would would be appreciated
Joe
I have not, but Ron (this Philco site owner) does coil re-winding. See here: http://philcoradio.com/rre/
Not difficult, but you need to have the exact number of turns and the same gauge wire as the original.
Also see this Service Tip from my website: http://www.philcorepairbench.com/tips/svctip36.htm
Enameled magnet wire is available many places. See the Resource Links on my site, but Radio Daze is a good place.
Hi Joe,
If you do decide to rewind your coil you can use a micrometer to measure the gauge and order the appropriate wire. You can find wire gauge specifcations on the internet. Just make sure you make a note which way the wire is wound on the form. An oscillator coil needs to be in phase with the incoming signal. It's not that hard to do really. Just a little tedious. Icon_biggrin
Hope this helps
It's quite possible you can get the coil going again by unwinding the coil back to the open point and repairing it. Hopefully it's not too far in.
Clean the wire ends and resolder them. Try using some fingernail polish over the connection to insulate it, then after it dries, re-wrap the wire around the coil. It might be a quick 'n simple fix, and would be worth a try before rewinding the whole thing.
Good luck, and keep us posted.
Bill
Sent from my Pentium II on the AT&T Dial Network
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3630 online users. [Complete List]
» 3 Member(s) | 3627 Guest(s)
