coronado console mid 30,s
Have a chance to buy an old Coronado console and can't find any info on it.
It has 12 tubes and 2 10 inch speakers with a round dial.
Anyone have any idea what model this could be?
I am guessing mid to late 30's.
Am also looking at a 1939 RCA K130 console.HAS 12 or 13 tubes.Supposedly working.
Is this one worth $75?
Great website.Keep it up.
Thanks
murf
Murf,
Only 3 - 12 tube models come up in this database search:
http://www.grillecloth.com/sylvania/tube...ubmit&db=1
Carl
Northern Panhandle, WV
I bought an RCA K130 a few years ago at the flea market for $65 if I remember right. It was complete and had a good original finish except for one place on the top where the finish had been removed. I think I would pay $75 for another. It does have 13 tubes including an eye and has motorized push button tuning. However, 8 of the remaining 12 tubes are the rectifiers and audio drivers and outputs. It also had rubber wiring that will need to be replaced.
Sean
WØKPX
Hello, Sean: I wonder why RCA found it necessary to use two 5U4G rectifiers for a 13 tube set? The 5U4 series is more than capable of supporting the 15 tube Philco 37-116!
RCA did this with some of their sets, examples would be the 8T14 (8 tubes) that uses a 5Z3 and the 262/263 (10 tubes), which on some sets uses two 80s. (other sets have a single 5Z3)
I depends on what shape they are in, a lot of parts missing, major parts missing, rust, or a dilapidated cabinet you may want to go significantly lower or even pass on them. If they are in average shape, all there but needing a refinish then $75 would be at the top end but still not bad if you are planning on keeping them, more so with the Coronado as opposed to the RCA. 1938-39 12 tube RCAs are more common then big Coronados and the 1938-39s suffer from plastic trim problems sometimes and rubber wire. I work on the ALASP principle, As Little As Possible when it comes to project radios.
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3170 online users. [Complete List]
» 4 Member(s) | 3166 Guest(s)
AvatarAvatarAvatarAvatar
