Restoring 38-7CS cabinet
I am restoring a 38-7CS for a customer, will use Mohawk aniline lacquer and their Finishers Choice Satin. This is my first experience with a radio!!
Questions:
1. Choice of stripper? The veneer is in good shape, but I know strippers can raise it. Lacquer thinner and then wash with denatured alcohol is my usual approach.
2. Should I apply a thin (1#) coat of dewaxed shellac to pop the grain prior to the med. brown walnut aniline. I usually use shellac in my restoration/new furniture business.
3. Very important! How to protect the "PHILCO" painted logo? I can mask around it with blue tape, is there any better way?
4. I plan on removing the radio from the cabinet to make the cabinet restoration process easier. Is this the usual practice?
Any and all insights/ suggestions will be greatly appreciated!
Thank you all.
Pete
I used Zinsser Citrus Action Gel on mine followed by Zinsser after wash. No issues with any grain raising. Then, I used Constantine walnut wood filler followed by Deft lacquer sanding sealer. Finally, Mohawk toner lacquer and Deft clear gloss lacquer.
It's all detailed in this thread: http://www.philcoradio.com/phorum/showth...p?tid=3653
Good luck
Thanks!
Your work looks great, I will study it and ask questions in the near future.
You say you "use Z. citrus action gel, followed by Zinnser after wash". Do you mean you use a Z. wash product or a Z. dewaxed shellac?
Pete
I think Bob is referring to Zinsser Magic Strip Citrus Action Gel, followed by Zinsser Stripper Wash.
Citrus Action Gel: http://www.rustoleum.com/CBGProduct.asp?pid=232
Stripper Wash: http://www.rustoleum.com/CBGProduct.asp?pid=239
If I am wrong, I am sure Bob will correct me. Icon_smile
Bob is another of our Phorum members who does excellent restoration work, and his YouTube videos have been a great help to many. Icon_thumbup
http://www.youtube.com/user/bandersentv
Yes Ron, that's exactly what I was referring too and thanks for the plug Icon_smile
To All,
I bought a knob from Mike Koste, purchased Mohawk lacquer toner/clear finish from a local Mohawk distributer (about 45 mins drive, 7.11/can).
Questions-not my last!-
1. again what is the preferred way to protect the "PHILCO" logo?
2. any tricks to disassembling the electronics and speaker from the cabinet? I haven't even looked under there except to verify that it is a 38-7CS.
I really appreciate the knowledge and the willingness of the phorum members to share!
Pete
you can get replacement decals from antique electronic supply ( http://www.tubesandmore.com )
p/n S-M907 $5.95 it should have the correct sized 'PHILCO' for your Philco
John
Las Vegas, NV USA
That will work if I screw up the original!
Thanks.
I am amazed at the resources available for this old radio.
Pete
peterc Wrote:2. any tricks to disassembling the electronics and speaker from the cabinet? I haven't even looked under there except to verify that it is a 38-7CS.
As I recall there are four small bolts holding the speaker on. Remove the nuts from the back while being careful not to damage the speaker cone. The chassis is mounted at a right angle and bolted to the underside of the top. I used a rachet wrench with extension to get up in there.
Good luck.
Thanks!
Show us some pictures please! thanks Doug Icon_smile
There are currently 2098 online users. [Complete List]
» 1 Member(s) | 2097 Guest(s)
