Philco ? Simplex
What is the story on the Philco/Simplex Radio that just sold for over $7000 on ebay. Was Simplex part of Philco at some point.
Can't believe the Radio is that valuable.
Cheers,
joybird
Hi,
Philco bought a controlling interest in Simplex in 1937 and by the 1939 season and beyond an increasing number of the Philco sets were made in the Simplex Sandusky complex. See http://www.firelandsradios.com/philco/
Thank You Paul
Very interesting
JB
Philco 91 Tuning Condenser
There are currently 8643 online users. [Complete List]
» 1 Member(s) | 8642 Guest(s)
