Where to find a pilot lamp for my 37/34
Am going to restore a 37/34 that has been around here for years. I have obtained a 6 volt wincharger system and now would be the time to have the old 6 volt radio restored.
A quick inventory of needs include the pilot lamp which is Philco part # 34-2150. Where can I find this bulb? The list on Chucks site does not have a generic bulb number listed for that Philco part. It is part of the series filiment string with an odd current rating.
If one cannot be found I could double a couple bulbs with half the current rating but would like to find an original if they are available.
Don
Yes you can parallel them to increase the current rating. What color is the bead just below the filament in the lamp?
ps I have the same set as a farm radio 37-33. You'll be surprise at it's performance!
From the 1941 Philco parts catalog:
34-2150 - 2.1V, 0.12A (120 mA). It has a miniature bayonet base and a tall cylindrical bulb.
You could substitute a #49 which uses half the current (0.06A or 60 mA). Less current is good for battery drain, but the bulb will not be as bright.
Terry, the bead color is missing along with the original bulb.
Ron, If I substituted a single 60 mil bulb wouldn't the voltage double acorss it and burn it out. It is in series with two other tubes and current would have to match. If less, the tubes would be starved for current and the bulb would have to handle the voltage lost.
I could hide the other bulb under the chassis I guess.
Don
OK, strike that.
DUH! Winning! Losing!
ahem...anyway, yes, I should have looked at the schematic first. If this were a parallel-filament circuit, it would work with no problems.
Very interesting filament wiring scheme. Three of the tubes are connected across the 6VDC line, with two others in series with the pilot lamp and resistors (7) and ( 8 ) also being across the 6VDC line.
Yeah convert it to take 2 of the #49 bulbs in parallel to replace the original. Make sence as the audio tube fillament is 2v/240ma and the mixer is 2v/60ma + the two resistors to limit the current.
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2716 online users. [Complete List]
» 1 Member(s) | 2715 Guest(s)
