16, 116x Alignment tools
What do you use to adjust the 1/4 inch nuts on the IF cans? Philco calls for a fiber nut driver.
All I have are the standard metal ones. I tried using that type, but it acts like an antenna and increases the signal making it hard to adjust and isn't as accurate.
Are there commercial tools I can buy for this purpose?
Hi Steve,
I think most people make their own. Here is a link to thread where I describe how I very easily made one out of an old ball point pen.
http://philcoradio.com/phorum/showthread.php?tid=1544
Here is a pic of the homemade alignment tool.
[Image: http://i135.photobucket.com/albums/q136/...Wrench.jpg]
Ed
Thanks. I tried it by heating up a1/4 inch hex bit and sticking it in the end of a pen blank. It held the shape well after I took it out and works well.
91H Code 126 Restore
