Philco 90 Tone control question
Does any one know what the capacitor values are for a Philco 90 tone control? Part #4037A, item 31 on the Rider schematic. thanks!
Kevin
Right from the Tone Control section of my Parts Values Page:
Four switch positions:
Point 1 - 0.0 Mfd. (open)
Point 2 - .015 Mfd.
Point 3 - .01 Mfd.
Point 4 - .01 Mfd.
http://www.philcorepairbench.com/tonectl.htm
Be sure to use 630 volt caps.
Chuck
Chuck Schwark Wrote:Right from the Tone Control section of my Parts Values Page:
Point 2 - .015 Mfd.
Point 3 - .01 Mfd.
Point 4 - .01 Mfd.
Chuck
Thank you Chuck!
Kevin
91H Code 126 Restore
