Another save - a Philco 655B
Uffda Wrote:Ron, since you brought up the bucking transformer I have to ask: Is there any danger in using a variable transformer like my Isotap or big honking Powerstat as a dedicated 110V outlet? I promise to exercise the knob regularly.
Phil (Uffda) - If your Variac is a nice, hefty unit, I suppose you could use it on a regular basis (as far as I know). I would feel better with the bucking transformer setup, though, for long term use.
I guess I wasn't thinking clearly Ron. Even if I use it at 110V, I want to be able to power up for modern stuff. Your way will work
better for a daily driver away from the bench.
By the way the Powerstat is 12 amps.
I've chronicled this restoration in detail, with lots of photos. It's part of the Restoration Notebook portion of the Phorum:
http://www.philcoradio.com/phorum/showth...?tid=14920
I love watching the transformation. The notebook is such a valuable resource. Your 70 cabinet is telling me to contact Mr. Jones about a de-shame job on my 90 or 70 or both.
Ron I saved this pic for future use when I restore my 655B cabinet. Best photo I could find of one
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
FYI the model 640 has "650" stamped in ink on the back of the tuning capacitor frame too.
Wow I would have to install a polycarbonate back and have it lighted to show that all the time. Its so beautiful. I hope to do that to mine when I'm done
Very nice restoration indeed Ron !!! Congrats!!! Icon_thumbup
Philco 91 Tuning Condenser
There are currently 4870 online users. [Complete List]
» 1 Member(s) | 4869 Guest(s)
