41-788 correct knobs?
Hi all,
New guy here, my name is Mike. I need a little help.
To the point: What are the correct knobs for a Philco Tropic 41-788 (the 2 left and 2 right knobs, the center IS correct)
The story: This Philco has been in my life since I can remember but hasn't worked in years. Now retired, I'm in the process of restoring it. Upon removing the knobs I discovered they are Hallicrafters knobs. Two 15B031 (could be 158031) on the right and two 81-003 on the left. The backs are embossed with manufacture and part#. I knew the righthand knobs were incorrect but had assumed the left one were correct, Wrong! They looked as if they belonged. Suspect my dad had something to do with it as he had several Hallicrafters in his shack.
Anyway, I believe Mr. Jackson (jgj6331) also has the same model Philco.
Mike
Mr. Ramirez has one also, as well as a 42-788. Icon_smile
The two left and two right knobs are identical to the knobs used on 1937-1940 Philco radios; dark brown with a small pointer.
Identical to this knob at Radio Daze:
http://www.radiodaze.com/product/15396.aspx
There are currently 7189 online users. [Complete List]
» 1 Member(s) | 7188 Guest(s)
