Transitone Information Model 2
I have a tube radio that inside has a label that says Philco Transitone Model 2. It is the tube unit only I do not have the dash piece with the dial pieces. I received this with a truck load of 1928- 31 Model A Ford parts. Any information on this is greatly appreciated. I am going to attempt to attach a couple of images of it. Thanks,, AL
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
It is a CT 2 ,it was built for the 1935 Chrysler,DeSoto,Dodge and Plymouth, depending on witch head control it had, the Airflow used a different radio, I've owned and worked on a few of these.
I once had a PT 2 that was built for the 1935 Packard, same radio only with an external speaker.
Bill: if you have worked on the C T2 chassis, do you have voltage readings for all the tubes? I could use that info to help me fix the CT2 I am trying to fix right now.
Also, on the tube pin layout, does pin one start just to the right of the 2 bigger pins?
Your help will be greatly appreciated by me. I am not very familiar with 1930s car radios.
Jay Icon_confused
Hey Jay
If you need the pin outs go here and down to about the middle there you will find a drawing of them.
http://www.philcoradio.com/phorum/showth...p?tid=2161
Here's the info on it: http://www.nostalgiaair.org/PagesByModel...013977.pdf
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
