Philco 90 RF coil pinout IDs
Hi,
Here's a photo of my problem in troubleshooting a Philco 90:
[Image: http://i1160.photobucket.com/albums/q498...rtA1-1.jpg]
The Rider's sheet mentions cryptic abbreviations for coil pins (I believe) but I haven't decoded them. Can anyone help? The 90 I have is apparently the latest model chassis and works with 24As in the front end but not with 35s. Also, the RF section is not working so I'm assuming it's in the Antenna input coil. It looks good (no apparent corrosion, and I haven't removed it) but all resistance readings are infinity.
Sounds like it's time to rewind!!! Am getting PB home page.
Thanks for the reply and note that the photo didn't show. Here's an address that I just tested and it seems to work. Some of the examples of the nomenclature giving me a fit are within the circled area.
[Image: http://i1160.photobucket.com/albums/q498...hartA1.jpg]
(The web address is contiguous without the separation caused by the question mark on line 1.)
Philco 91 Tuning Condenser
There are currently 5218 online users. [Complete List]
» 1 Member(s) | 5217 Guest(s)
