  • 1 Vote(s) - 5 Average
Fun with external loop antennas
#31
BTW, thanks to Brian for all the info. It would have been much more difficult without it. Also, I forgot to mention that my loop is the 25 inch square model.
And oh yes, credit where credit is due. That Silvertone 4586 is Andrea's. Icon_lol She bought it at the MARC swap meet in Lansing last July.
Ed
#32
Ed a buddy has one. I seem to remember that is a fairly hot set.. Likes spitting out all those electromagnetic waves that invade it's space 8)
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
#33
BTW, can you identify that radio shown in the background of the last pic?
Ed
#34
38-690
-Brian
#35
Correct! Being that this is the Philco Phorum, I had to put something Philco in my post. Icon_lol
Ed
#36
Only problem I see in that photo. Is that is not a shot of my front room where a 38-690 should be Icon_twisted Icon_surprised Icon_angel
-Brian
#37
After building my first loop antenna, I discovered two problems. One, I don't have a good place to put it. Two, loop antennas are incompatible with cats (we have two). Searching the Internet I ran across an article about a Hula-Hoop-Loop, so I built one.
[Image: http://i985.photobucket.com/albums/ae335...4_3390.jpg]
The Hula-Hoop is about 33 inches in diameter. I pulled the hoop apart at the joint looped a four conductor telephone cord through two times. I connected one end of one conductor to the other end of the next conductor and so on to create eight loops. I added single wire loop for the sense loop. As it turns out it wouldn't tune the high end of the band. I removed two turns. Now I'm loosing a little of the low end. As I have time, I will play with this some more.
M R Radios   C M Tubes
Philco 91 Tuning Condenser
There are currently 4333 online users. [Complete List]
» 2 Member(s) | 4331 Guest(s)
