Chairside Identification
This picture was taken in my grandparents house. I don't know who the kids are but I'd like to find out what kind of radio that is. I'm assuming it is a radio phonograph but I'm not sure. If anyone has one for sale I'd be interested.
http://beingthere.smugmug.com/photos/126...ZbF-X3.jpg
Well I can tell you what it isn't, it isn't a Philco. I seen a lot of chairside set but this one doesn't look familiar at all. You may want to ask around other family members to see if they can give you any info on it. If you can come up with the name of the manufacture I can probably come up with the model for you.
Philco 91 Tuning Condenser
