Admiral Cartridge and needle
Hello
I was wondering if anyone knows of a place to get a cartridge and needle for a 1950's Admrial radio record player. The part number is A1372-13.
Thanks Bob
There are currently 8985 online users. [Complete List]
» 5 Member(s) | 8980 Guest(s)
AvatarAvatarAvatarAvatar
