Wood veneer species ?
Hi again! Icon_wave
First of all, a big THANK YOU to Ron for answers my knob questions. Icon_thumbup
Here's my next query; what is the wood species on the 41-788?
Mike
Looks like Mahogany to me..
-Keith
46conehead Wrote:Hi again! Icon_wave
Mike
On what part of the 41-788's cabinet? From the photo in the gallery it looks like French walnut on most of it, possibly stump walnut near the knobs if that portion is real, do you have an photos of your cabinet?
Thanks, I believe your answer has gotten me close to what I needed.
Took me awhile to research similar woods and get back to you. Thanks again
Mike
Must say, Arran has a good handle on wood varieties.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
