Philco 38-9k
fixinmyphilco Wrote:Ok Question As this is the first time I have fixed a Philco.The 3 knobs on the bottom, the right is on and off ,the middle is the band switch but the left? Is that tones? Thanks Doug
[Image: http://i1095.photobucket.com/albums/i474...co3iy7.jpg]
bump for question
Yep. On/Off-volume, band, tone <<<<<<<<<<<<<<<<<<<<<<<<
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
ty ty
Started sanding it down to bare wood almost ready to seal and varnish
[Image: http://i1095.photobucket.com/albums/i474...hoto00.jpg]
Ok shes almost done a few more coats of varnish and it will be finished Came out ok I guess and plays great with the 50 foot antenna I put up outside.Sorry only my phone camera is working at this time. [Image: http://i1095.photobucket.com/albums/i474...to0112.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0111.jpg]
Looking good. We need some better pics. Icon_clap
Here's some more [Image: http://i1095.photobucket.com/albums/i474...IM1613.jpg]
[Image: http://i1095.photobucket.com/albums/i474...IM1614.jpg]
Wow. Not only did you do a really nice job, that is a breathtaking cabinet.
Thanks I do the best I can. Doug
Speaker still looks nasty, I'm guessing coffee filters and white glue, but if nobody ever sees it, guess it's OK. Otherwise a really nice set.
You're building up a pretty good collection of radios there Doug. They're all nice looking sets.
Dave
Philco 91 Tuning Condenser
There are currently 4796 online users. [Complete List]
» 1 Member(s) | 4795 Guest(s)
