41-616 SW antenna needed
Hello all
Back with a new twist to the "beast" rehab. Apparently the shortwave antenna is missing from this set, among other things. Thanks to Al Corbin the chassis is mostly functional including the Mystery remote. However in trying to assess SW functionality he asked me for antenna loop dimensions to replicate a test antenna. I cannot find one in the cabinet.
Any help getting spec's for this antenna would be greatly appreciated...!
I assume that similar models would use the same antenna so maybe that's an alternative source of information.
Thanks
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7035 online users. [Complete List]
» 2 Member(s) | 7033 Guest(s)
