I really want to understand old radios.
Threads: 9
City: Oregon
(03-10-2012, 01:13 PM)codefox1 Wrote: Old Police band is useless. Get rest of set to work.
Thanks, Thought so, since it is 1700 KC up.
Set does work, just weak. I was just thinking out loud that if I can't glue the band selector back together to just by-pass it to AM.
lyle
I may not be very good, but I'm slow.
Threads: 54
(03-10-2012, 12:58 PM)lyle Wrote: (03-10-2012, 08:44 AM)7estatdef Wrote: (03-10-2012, 12:55 AM)TA Forbes Wrote: Hello, Lyle: I would be glad to offer any assistance that I can, but I must tell you that there are MANY fellows here on the Phorum that are WAY better radio guys than me. What I especially like about this site is the people that contribute to it. Here you have a valuable resource for radio questions.
I'm definitely NOT an expert on wimmen, as two divorces and numerous failed relationships will attest. In fact, I don't even call my ex-wives by their name any more, I just call 'em both "plaintiff."
So wimmen questions are best left for others.
I discovered that the volume control I need was used in several Philco sets, including the 20, 46, and 70. I also discovered that the 1st IF transformer was open, so now I am searching for one of these too.... Hey Tom
I can probably help you out with the volume control from a mdl 20.
Terry No worries, TA, I don't know enough to ask hard questions. I made a discovery of my own. This Philco 60 has a break in the phenolic wafer of the Band Selector. It is now in two pieces on my bench. It's been suggested I use super glue. Finding a replacement probably won't be easy.
If I can't fix it maybe I can just by-pass it to the AM band. I don't think there really is a police band left.
lyle
You could bypass the switch to make it work but on these sets the lower end of the old police band is the top end of the AM broadcast band. The old AM broadcast band stopped at 1500 KC, the current one goes to 1700 KC, so to get stations above 1500 you need the police band working on a Philco 60.
If you want to learn about old radios there is a book out there called "Elements of Radio Servicing" by Marcus and Levy, it's out of print but there are a lot of copies still out there.
(This post was last modified: 03-10-2012, 09:50 PM by Arran.)
Threads: 9
City: Oregon
(03-10-2012, 09:37 PM)Arran Wrote: (03-10-2012, 12:58 PM)lyle Wrote: (03-10-2012, 08:44 AM)7estatdef Wrote: (03-10-2012, 12:55 AM)TA Forbes Wrote: Hello, Lyle: I would be glad to offer any assistance that I can, but I must tell you that there are MANY fellows here on the Phorum that are WAY better radio guys than me. What I especially like about this site is the people that contribute to it. Here you have a valuable resource for radio questions.
lyle
Thanks Arran. I have a copy of 'Essentials of Radio' by Slurzberg & Osterheld, printed in 1948. Got it on ebay. Will look for 'Elements...'
I did repair the band selector switch today with superglue and epoxy. What a relief.
Thanks again,
lyle
Threads: 92
City: Clayton, NC
The police band on a 60 is 1.5 MHz to 4.0MHz. Arran is right, the top end of modern AM broadcast band is "police band" on your set.
You can still pick up some "interesting" shortwave programs with the police band available on your model 60.
Threads: 9
City: Oregon
OK, I'll bite. What do you mean by "interesting?"
lyle
Threads: 92
City: Clayton, NC
Some foreign french and spainish programs, some Christian broadcasts including one fellow who claims to be a modern day prophet, (I am a Christian, FYI), Voice of America, and a broadcast that is Conspiracy Theory oriented.
Your antenna system will detirmine what you are able to pull up.
Threads: 9
City: Oregon
Well, TA, I do have a 90 foot long wire. I get Australia and Romania pretty easily on my home-brew 1-tube Regen. So, it should be interesting. Hoping I get the conspiracy Theory one. Have a SONY SW, but haven't gotten anything that interesting. I'm not a Christian, quit the Catholic church at age twelve on the day of my confirmation. That's the day Catholics confirm their faith. Ironic huh?
lyle
Threads: 9
City: Oregon
Wilco, Codefox1
lyle
91H Code 126 Restore
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
>>and found that the field coil is bad. Should be 1140 ohms, tests at 1.1k ohms.
You have one stringent crit...morzh — 02:07 PM |
Yes I was there. I got some real bargains there. Plus a Zenith 7G605 clipper that I have been trying to find for a fair ...Radios1340 — 01:46 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
