Philco doublet antenna installed
So, decided to stick up my Philco di-pole (doublet) antenna today. Results = fantastic! No doubt a nice improvement over my long-wire. This of course works in conjunction with the tuned antenna attachment points internal to the radio. Noise is lower. Good ground has little effect on the noise due to the tuned nature of the doublet (really the tuned input in the radio). Naturally the antenna itself is nothing more than a 60' di-pole. You could make your own. Simply cut up a 30'/30' di-pole and feed it with a twisted pair to the tuned antenna attachment points.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Icon_thumbup
(03-18-2012, 11:41 PM)TA Forbes Wrote:  Icon_thumbup
I later added another 20' to either end for a total of a 100' dipole. That improved things even further all across the bands. Those tuned inputs do work compared with the straight wire input (and ground).
-Brian
For the BCB your will need about 500' per side to be resonant. At 100' your resonant at about 10Mc. I've got about 120' up in the air at 35' or so and it works well. The higher up the better, unfortunately I don't have any tall trees just 40' pines.
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 3285 online users. [Complete List]
» 1 Member(s) | 3284 Guest(s)
