Threads: 30
City: Grand Rapids, MI
Just brought home an EH Scott Allwave 15 from an estate sale, thanks to Ron for instant help in identifying this set from the picture and the encouragement to go and get it. Don't know much about EH Scotts. Chrome looks pretty good, all tube shields and coil covers, transformer shells are present, cabinet only minor nicks here & there, no apparent tears in the Scott pedestal speaker, looks to be complete and this radio, even without the amp chassis in the cabinet is HEAVY! Came with the instructions manual.
I'll post some pix when I figure out how. Got to get my genius brother to help me figure things out I'm not that compooter savvy.
Mike
Threads: 18
(03-19-2012, 11:50 AM)Mikhail7 Wrote: Just brought home an EH Scott Allwave 15 from an estate sale, thanks to Ron for instant help in identifying this set from the picture and the encouragement to go and get it. Don't know much about EH Scotts. Chrome looks pretty good, all tube shields and coil covers, transformer shells are present, cabinet only minor nicks here & there, no apparent tears in the Scott pedestal speaker, looks to be complete and this radio, even without the amp chassis in the cabinet is HEAVY! Came with the instructions manual.
Mike
Congratulations, you have a treasure. I'm sure you will take the restoration slow and steady. Withe this type of set, you are self elevated from restorer to curator, if you get my drift.
Threads: 92
City: Clayton, NC
Threads: 30
Hi Codefox,
Thanks, just the look of the chrome shouts CLASS! I had no idea what the radio was in the sale picture so I sent it to Ron. A really quick ID too. He persuaded me I should go for it.
I never dreamed this downtown lackey might actually rub shoulders with the Hahvard gentry. Oh, do turn on the stock report and fluff me, won't you, Gilligan?
Mike
Threads: 30
Hi TA,
Thanks, I think we posted at the same time.
Me, I'd have said who'd a thunk it, this ritzy radio showing up like it did. Ron says he's never seen the style cabinet it's in. It isn't anything really ornate but it's in pretty good shape. I feel very privileged to have found this and the 37-690 in November.
Mike
Threads: 30
Has anyone here ever removed a chassis from the cabinet of this era of an EH Scott? Seems like there's some nuts that require a nut driver for removal from the top, there's nothing on the bottom of the chassis board.
Mike
Threads: 2
City: Christchurch
State, Province, Country: New Zealand
I've just taken one of these sets in for restoration. What a behemoth! After re-stuffing all the wee capacitor cans & replacing all out-of-spec resistors, I have the powered it up. The audio & IF sections are all fine but I cannot get the local oscillator to cooperate. Any suggestions? Also the mixer tube in this particular set is a 58, not a 2A7 as the two circuits I have found, show. The circuit of the audio amp is also a bit different. The detector is the full-wave type using both diodes of the 55 valve and the Radio Museum info suggests that this was employed in a later version of the circuit but the 58 mixer would suggest otherwise. I therefore assume that there are other circuits somewhere out there. All very interesting. Michael, does your manual contain a circuit that you could copy for me please?
Threads: 154
City: Westland, MI
Hello Philconut. This thread is over twelve years old. I am sorry to inform you that Michael Dennis passed away several years ago. Looking under his name you see the status "silent key". That's to let others know that they are deceased. Take care and BE HEALTHY! Gary
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
