? WHAT MODEL is this Cabinet?
OWner insist this is a radio Cabinet. I question that any one know what model of philco this is?
http://www.flickr.com/photos/trog8/sets/...705192059/
I just received a photo of the same cabinet (with doors closed).
Looks like a early to mid 1950s Philco TV cabinet to me.
(03-30-2012, 10:00 PM)Ron Ramirez Wrote:  I just received a photo of the same cabinet (with doors closed).
THAT'S what I said she instead a Radio was in it. She could not provide a model number and when i ask about the knobs she they wen under the bars like nothing i have seen.
is the pic from someone in calif?
Philco 91 Tuning Condenser
There are currently 3646 online users. [Complete List]
» 2 Member(s) | 3644 Guest(s)
