Source for Philco speaker bolts
Does anyone know where I can get 4 decorative bolts and nuts to connect my Philco 37-620 tombstone speaker to the wood frame?
thanks
Chris
Don't any of the decorative screws AES sells match or aren't correct length? http://www.tubesandmore.com Search for decorative screws.
Also try PlayThings of Past: http://www.oldradioparts.com
Chuck,
Thanks for the links!
chris
There are currently 9560 online users. [Complete List]
» 2 Member(s) | 9558 Guest(s)
