How do I tell a which version 91 Cathedral I have?
I got this the other day, and I am driving myself nuts trying to figure out which version this is 91A, 91B ???? I am clueless can anyone help???
Thanks
Rock
(04-19-2012, 03:21 PM)rocklandman Wrote:  I got this the other day, and I am driving myself nuts trying to figure out which version this is 91A, 91B ???? I am clueless can anyone help???
Thanks
Rock
The tag says it all. You have a U.S. Philco Model 91, Code 123.
The B stands for Baby Grand. See Ron's site here for cabinet designations: http://philcoradio.com/tech/letters.htm
By the way, if you had a Model 91A, it would say A on the tag and it would also be a Canadian version and would also indicate this as well.
Basically the power transformer is different, due to power differences back then in Canada. 25Hz instead of 60Hz mainly.
Chuck
WOW!!! Thank you Chuck!!
Thanks
Rock
Chuck
Philco 91 Tuning Condenser
There are currently 4696 online users. [Complete List]
» 1 Member(s) | 4695 Guest(s)
