Old Russian / Soviet tube radios
In this one both lines go to the power switch, so swapped all you want Icon_smile - that won't help much.
Polarized plug.....not much safety in it.
Also mistakes in house wiring when Hot and Neut. are swapped are common.
Better yet (found this one doozie in my house), when some idiot wires the hot and neutral in the same line from different breakers. Guess what happens when you think you switched it off Icon_smile
There are currently 10532 online users. [Complete List]
» 2 Member(s) | 10530 Guest(s)
