station call letters
Just one this off ebay. Does anybody need any? Have not recieved it yet but thought I would ask now. I have a few radios that are in need of these but thought I would share them with any other philcophiles.
http://cgi.ebay.com/120056798968
thanks
Chris
Chris..do you still have the call letters: WHAS, WIBC, WSM, WLW, WAVE, WGN...Thanks, Terry
Terry,
I have the following for you.
WIBC
WHAS
WAVE
They are yours just send me your address.
thanks
Chris
Philco 91 Tuning Condenser
There are currently 6956 online users. [Complete List]
» 3 Member(s) | 6953 Guest(s)
