39-30 pushbuttons
I have recently purchased a 39-30 in beautiful condition that works still! Anyway, the push buttons are missing off the front. Could anyone please tell me where I can find some? Thanks
Hi Libby,
You might try Larry at: http://www.antiqueradioknobs.com/
Carl
Northern Panhandle, WV
There are currently 9362 online users. [Complete List]
» 2 Member(s) | 9360 Guest(s)
