Philco bakelite condenser 4989 Z?
Hi,
I just started a restoration of a model 60 cathedral and came across a bakelite condenser 4989 Z. According to the schematic I have it is a .18 single but upon removing the wax there are two caps inside. I was on philco repair bench and a Z version is not on there for a 4989. I have 0.22uf caps can I use these and what pin is the double? Just want to be sure.
thanks
Chris
Hi
The 4989-Z has two .09 uF caps in parallel to make .18 uF. You will note there is an external jumper wire between the center terminal and the outermost terminal; the grounded terminal is common to both caps.
Yes, you can use a single 0.22 uF in place of the two, or two single 0.1 uF caps. Close enough for gubmint work, as they say.
Ron,
Thanks for the information. I do have two 0.1 caps. Good thing I asked I was going to use two 0.22 caps. It was not labeled as a double condenser on the schematic I have. Is this typical? Which pin is the ground pin?
thanks
Chris
The screw hole is the ground in that particular block.
Ron,
Chris
91H Code 126 Restore
There are currently 5661 online users. [Complete List]
» 1 Member(s) | 5660 Guest(s)
