Mystery inductor- 37-660
I'm not holding my breath waiting for an answer but here goes:
On the 37-660 IF amplifier (6K7), the suppressor grid (pin 5) has a coil to ground. Since my radio has been tampered with, this coil is missing. There is no component designation for this coil and the schematic is kind of blurry.
What is the purpose of this coil? I'm inclined to replace it with a couple of turns through a small ferrite ring or simply ground it and hope for no spurs or stray coupling. Can anyone tell me what the schematic is supposed to read?
Pete AI2V
That tertiary (TER-she-ary) winding is in the first IF transformer. If someone has removed the connections to it from the can, just ground the SUP grid.
See the GRN-YEL tracer and bare wire color designations on the schematic pointing to that winding?
Cannot remember the theory behind that circuit. Have to try to remember where I saw the explaination.
Thanks Chuck- I didn't look inside the IF can since the schematic gave me no hint. Since it's in the IF can it would seem that it might kill some sort of oscillation with negative feedback.
This is a terribly difficult radio to work on, especially in the oscillator section. I'm making test probes out of thin bus wire and had to put an LED on the end of wire to see anything. I'm even changing the tube sockets so that I will never have to go back into it. Tnx again for fast response and good info.
Pete AI2V
Yes, the schematic does not show the three coils within a dotted line or something to let you know that the coil is a winding in the can. Good luck.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 7030 online users. [Complete List]
» 2 Member(s) | 7028 Guest(s)
