05-10-2012, 12:55 PM
Great work. You should be proud of your efforts!
Thanks
Mike
Thanks
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Philco 15DX restoration
Thanks Mike Cossor 3468 GE 417A Philco 118H Radiola 17/100 Scott 800B6 Silvertone 6130 Stromberg 535M Truetone D1952
05-11-2012, 12:45 AM
Thanks. I've progressed over to this corner without incident until now.
I found several circuit modifications in this area, but I don't think this broken solder connection was intentional. I'm going to restore the wiring and component values to match the schematic. [Image: http://farm8.staticflickr.com/7104/71746...21ce_z.jpg]
05-11-2012, 02:01 AM
(05-11-2012, 12:45 AM)bandersen Wrote: Thanks. I've progressed over to this corner without incident until now. That does look like the work of a weekend radio mechanic, or a quick and dirty service shop. Something I've run into all too often, parts detatched, solder junctions floating in space, etc. This is one of the reasons that I always pull the chassis and look underneith before trying to power up the set on the variac. Initial inspection of a Stromberg and a Canadian Westinghouse set I picked up last year dissuaded me from powering those up, one had crumbling wire, the other a dangling burned flexable resistor and lots of 40 year old service work that needed checking over. Regards Arran
05-11-2012, 07:56 AM
Nightmare of dogbones. It's going to take some time to get right.
05-13-2012, 08:09 PM
I hope someone with a 15 chassis can help me out with this one.
I found this cap crudely solder across the #42 tube plates. [Image: http://farm6.staticflickr.com/5469/71922...84a7_z.jpg] I got a copy of the 15 schematic from Chuck which shows it as #57, but no value. [Image: http://farm8.staticflickr.com/7230/71922...3b7f_z.jpg] The parts lists shows #57 as a 240,000 resistor across the volume control - not illustrated. There's no resistor across my volume control though. It does list #58a as 0.002 mfd cap across the output transformer primary. Perhaps this is the capacitor in question ? [Image: http://farm8.staticflickr.com/7105/71922...2de7_z.jpg] Finally, to make matters more confusing, I dug up an original Philco schematic and it shows #57 as a resistor across the #42 grids and no cap between the plates ![]() [Image: http://farm8.staticflickr.com/7092/71923...ec82_z.jpg]
05-13-2012, 09:33 PM
http://www.nostalgiaair.org/PagesByModel...013138.pdf
Look at the changes made depending on the run number, on the bottom of the schematic page. It mentions everything you talked about. ![]() Hope this helps. Ed
05-13-2012, 09:56 PM
Is there a reistor underneath that mica or micamold cap? It looks like there is something pigtailed across the leads. According to the dot code it's 200,000 mmf or picofarad, unless I misread it, so that's .0002 micrfarad, the correct value according to the schematic. Hopefully it's not paper inside but given the size it could be either paper or mica.
Regards Arran
05-13-2012, 10:13 PM
Thanks Ed. Yes, that sure does help make sense of it all
![]() Arran - there are two micamold caps pigtailed together and very crudely soldered in place. I'm sure it's a later addition to the set. That makes me think my chassis is below run 22. I guess I should make the production changes mentioned then. I just restuffed my first bakelite block with a resistor in it. I'd read about them, but never encountered one before. I replaced the resistance wire with a modern metal film resistor. [Image: http://farm8.staticflickr.com/7075/71922...76d2_z.jpg]
05-14-2012, 12:29 AM
Bob;
I think that I may have encountered a bakelite block with a resistor in it but I'm not sure, they mostly prefered to connect them on the outside. I have run into ones with a pair of micas potted on the inside fo a tone control or some such thing, it was a while ago mind you. Opps, I misread the schematic, it was .002 not .0002, or a fraction of what it is supposed to be, what value of micamold did the parallel onto the backside? Regards Arran
05-14-2012, 12:46 AM
I haven't separated them yet, but I put them on a cap tester and got around 0.0018 and no leakage. Even so, I think I'll replace them with a modern 0.0022 poly cap.
05-14-2012, 12:50 PM
Yes, that would be fine. It's there to quash high frequency oscillations. Use at least 1000 volt type. Better yet 1600 volt. Dress the same as the old one.
05-15-2012, 09:24 PM
I have a 1,600 volt orange drop on the way
05-16-2012, 12:59 AM
I checked out the volume control tonight and the resistance varies from 0 to about 1.7 M. The schematic doesn't specify a value but 6694 matches the parts list. Does anyone know if 1.7 M is in the right ballpark ?
[Image: http://farm8.staticflickr.com/7089/72076...c4e2_z.jpg]
05-16-2012, 05:27 AM
I can't find 6694 in any of my early-mid 1930s Philco parts catalogs. They call for either 7050 or 8054.
Only the value for 8054 is given, 350K. The 1946 catalog specified either 45-5013 (350K, linear taper) for early models or 45-5011 (350K, audio taper, tap at 70K) for later models. I think we can conclude from this that the value should be 350K, not 1.7 meg. -- Ron Ramirez Ferdinand IN
05-16-2012, 01:55 PM
Thanks for the info. I'll unmount it for a closer inspection. Maybe a little contact cleaner will help ?
« Next Oldest | Next Newest »
Users browsing this thread: 37 Guest(s) |
