Philco 46-200 122 SW Band?
Hi everybody,
Finally got my little Philco 46-200 122 working, but for the life of me, I can't figure out how the SW band works. The dial is marked Broadcast and 200 to 500 meters, but no band-switch.
Using the Breitman Schematic.
I hesitated to ask because it's probably obvious. Just not to me.
lyle
I may not be very good, but I'm slow.
Huh the 200-500 meters is the AM band measured in wavelength rather than frequency. This set has no SW band.
No wonder I couldn't find it. See, it was obvious.
Thanks once again, Terry.
lyle
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3440 online users. [Complete List]
» 1 Member(s) | 3439 Guest(s)
