6 meg pot needed?
I just re-capped a Philco 48-1263 and it sounds pretty good, but I have a question about the switched pot for on/off and tone control. It had obviously not an original one on it, the schematic calls for a 6 meg and this was a 500k. There was no tone variance and also it smoked now and then, pretty scary to me. I stuck a new 1 meg on it and no more smoking, but there is still no tone variance. I assume that I do need a 6 meg pot, nothing less. Where will I find such a thing? Only by cannibalizing another radio? As always, thanks so much for your knowledge guys.
Alan
That, or by contacting Mark Oppat:
http://www.oldradioparts.net/
Thanks for the reply Ron, I've sent a message off to Mark Oppat. Does it make sense that I won't have a tone variance without the 6 meg?
Alan
Well I'd have a look at C205. Ground the end that goes to the pot. If all is well it will reduce the high frequency response. If not replace it.
The speaker table error?
Philco 70 antenna lead
There are currently 7085 online users. [Complete List]
» 1 Member(s) | 7084 Guest(s)
