New Philco 51 question/ANSWERED
On my Riders, for the alignment it says to refer to the "illustration above for the location of the various compensating condensers." There is no illustration above. The parts layout does assign a numbers to the comp. conds., but I can only find them on the schematic, which isn't enough for me. I would also need to know which trimmer is which on top of the tuning cap. Any help out there?
http://www.nostalgiaair.org/PagesByModel...029635.pdf Page 2, last paragraph describes where and which are which.
http://www.nostalgiaair.org/PagesByModel...029633.pdf This is a 50 schematic but the antenna adj are shown which are in the same place as the 51.
Thanks-DENNIS
Philco 91 Tuning Condenser
There are currently 4678 online users. [Complete List]
» 2 Member(s) | 4676 Guest(s)
