Edison Radio
Saw this Edison R7 radio on Ebay. Item 110879184375. Looks worthy of restoration if you are in the Louisville, Ky area.
Those early Edison/Victor sets can be a booger to work on. I still have recurrent dreams about an R32 I did 30 years ago.....
No bad looking....not an expert on prices, but 100 bucks is bearable.
It's alright if you really want one, but I wouldn't go out of my way to get it, other then the name it's another generic four legged console from the 1928-31 period. A radio in this sort of shape would be under $75 at a swap meet with the paper work, under $50 without, the finish is completely shot and flaking off. Most of the tubes appear to be later ST style replacements except for the Arctrus #27 tube, the set also originally had a back with a cloth in it, the frame is still there. You have to remember that even electrically restored and refinished it isn't worth $250, so the only reason to get it is because you like it, not for profit. One thing that will kill you on anything other then a local pickup is the shipping, in fact that's the number one thing that causes console sales to fall through.
Philco 91 Tuning Condenser
There are currently 7590 online users. [Complete List]
» 2 Member(s) | 7588 Guest(s)
