TH-4 across the line cap
I can not read the crappy schematic I have. Someone put a .15mf cap across the power line but this seems high. Can someone please let me know what the value of the cap is? The really packed all the caps underneath this chassis. The rubber coated wire is driving me nuts also. Icon_crazy
thanks
Chris
cap #25 .03/400v
Thanks for the information. Will have to see if I have that value in a safety cap and try to squeeze it into the chassis.
thanks
Chris
Any cap under or about 1uF across th power line is fine, and the higher values do not hurt anything. Just make sure it is X-rated.
The speaker table error?
Philco 70 antenna lead
