What is the correct resisior wattage
I'm working on a 41-285F that is coming along nicely. I'm about to replace the out of spec resistors and would like to know what wattage rating I should use. For example, there is one 10M ohm resistor that passes less than a volt, would a 1/4 watt rating be too small or should I go higher? The original is pretty small in size.
Rick
That 10,000 ohm resistor can be a 1/2 watter. Most resistors are at least 1/2 watts, other than any power resistors. 1/4 watt resistors were not "invented" then.
A 1/4 watt resistor will NOT have the voltage rating that a 1/2 or 1 watt resistor has. A 1/2 watt resistor has about a 250 MAX voltage rating, so keep this in mind.
Thank you Chuck,
This is the first Philco I've worked on and it's been a long time since I've worked on a tube radio. I'll search for a 1/2 watter.
Rick
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2671 online users. [Complete List]
» 2 Member(s) | 2669 Guest(s)
