Philco 030 Dyamic tester
Does anyone have any info on these. I just won one and was wondering what they were used for and if anyone has a manual and schematic for it.
thanks
Chris
Do you mean one of these?
http://www.myvintagetv.com/Apple%20PDF%2...Tester.pdf
There's the explanation.
Unsure if that is the one. Here is the link to what it looks like.
http://www.ebay.com/itm/200763342766?ssP...1497.l2649
Do you have one?
thanks,
Chris
Looks like a signal tracer.
It is a cheaper copy of the same, I guess.
What it is is a signal tracer that allows to listen to the signal by detecting and amplifying it at every stage.
The other is just more complex tracer.
I have the testing procedures, schematic and parts listing for the Model 030 Dynamic Tester. Listed in the 1946 Philco Radio Test Instrument Manual. Just use the regular Schematic Info page order form on my site for a photocopy of these pages.
A 4 tube signal tracer for RF and AF signals in a typical radio.
Regards,
Chuck
[/u]
Chuck,
Thanks! Will order that ASAP.
Chris
Chris,
I have the instruction manual w/schematic posted on my site:
http://www.myvintagetv.com/manuals_and_documents.htm
I do have a large number of Philco test equipment manuals if you need any others. I usually don't scan them until someone is looking for one.
Chuck
www.myvintagetv.com
Chuck A,
Welcome! So that's your site, eh? Very good...I have used it to obtain some McMurdo Silver info recently. Thanks for making this resource available to us!
Ron,
Glad the site was useful to you.
Chuck
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6868 online users. [Complete List]
» 1 Member(s) | 6867 Guest(s)
