Emerson DB-296 Kicking My Rear End Hard!
For the last two days I've been trying to get an Emerson DB-296 that I bought last weekend at a swap meet. It didn't play when I purchased it. I've re-capped it, checked the resistors, checked the tubes, etc. etc. etc. I have audio, but little if any signal. I've aligned the IF cans, checked continuity on all coils.
I checked tube voltages and here's what I have:
TUBE = 12SA7
PLATE ACTUAL 95 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 106 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 12K7 (NO PLATE OR SCREEN VOLTAGE)
PLATE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
TUBE = 12SQ7 (REALLY HIGH ON THE CATHODE VOLTAGE)
PLATE ACTUAL 55 = RIDERS SAYS IT SHOULD BE = 30
SCREEN ACTUAL 1.5 = RIDERS SAYS IT SHOULD BE = 0
CATHODE ACTUAL 103 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 50L6
PLATE ACTUAL 86 = RIDERS SHOULD BE = 82
SCREEN ACTUAL 5.4 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 6.0 = RIDERS SAYS IT SHOULD BE = 5.6
Any suggestions would be greatly welcomed!
I always considered it a good and consderate thing when the asking party psts a link to the sch in question intead of sending those trying to help to search for it.
We are willing to help but why make us do the legwork?
There are currently 3542 online users. [Complete List]
» 2 Member(s) | 3540 Guest(s)
